Le Deal du moment : -38%
Ecran PC gaming 23,8″ – ACER KG241Y P3bip ...
99.99 €
 Option pour l' exo
tibure
7 participants
Option pour l' exo  Empty
MessageSujet: Option pour l' exo    Option pour l' exo  Icon_minitimeSam 21 Avr 2012 - 11:02
Un post consacré aux options ou les trouver ect......
Axial option celle que l' on voit dans la notice Wink
AX30415 EXO™️ Front Universal Joint Axle Set (2pcs) AX30815
Option pour l' exo  Ax30417-1_200x134
AX30417 EXO™️ Rear Universal Joint Axle Set (2pcs) AX30817
EXO™️ Heavy Duty 32P Steel Spur Gears
AX30851 Steel Spur Gear 32P 48T
AX30852 Steel Spur Gear 32P 50T
AX30853 Steel Spur Gear 32P 52T
AX30854 Steel Spur Gear 32P 54T
Option pour l' exo  Ax30851-1_200x134
Axial 32P Steel Pinion Gears
Arbre 3mm
AX30722 Pinion Gear 32P 11T (3mm shaft)
AX30723 Pinion Gear 32P 12T (3mm shaft)
AX30724 Pinion Gear 32P 13T (3mm shaft)
AX30725 Pinion Gear 32P 14T (3mm shaft)
AX30726 Pinion Gear 32P 15T (3mm shaft)
AX30727 Pinion Gear 32P 16T (3mm shaft)
AX30728 Pinion Gear 32P 17T (3mm shaft)
Arbre 5mm
AX30837 Pinion Gear 32P 11T (5mm shaft)
AX30838 Pinion Gear 32P 12T (5mm shaft)
AX30839 Pinion Gear 32P 13T (5mm shaft)
AX30840 Pinion Gear 32P 14T (5mm shaft)
AX30841 Pinion Gear 32P 15T (5mm shaft)
AX30842 Pinion Gear 32P 16T (5mm shaft)
AX30843 Pinion Gear 32P 17T (5mm shaft)
Option pour l' exo  Ax30722_200x134
AX30825 EXO™️ Machined Aluminum Front Shock Tower AX30825
Option pour l' exo  Ax30825-1_200x134
AX30826 EXO™️ Machined Aluminum Rear Camber Tower AX30826
Option pour l' exo  Ax30826-1_200x134
AX30815 EXO™️ Machined Aluminum Steering Rack AX30815
Option pour l' exo  Ax30815-1_200x134
EXO™️ Machined Aluminum Toe Blocks AX30811
Option pour l' exo  Ax30811-1_200x134
AX30860 Machined Motor Plate
Option pour l' exo  Ax30860-1_200x134
AX30091 EXO™️ 67-90mm Shock Set (2pcs)
Option pour l' exo  Ax30091-1_200x134
AXA1076 Cap Head Washer M3x10mm (4pcs)
Option pour l' exo  Axa1076_200x134
Source http://www.axialracing.com/ftp/press.html
Hot racing ( divers pièces alu et autres )
http://www.hot-racing.com/index.cgi?c=697
GCM racing ( diff alu , plaque moteur en 1 pièce )
http://gcmracing.ca/viewcategory.php?groupid=32
xtremercracing (carbone)
http://www.xtremercracing.com/EXO.cfm
Teamstrc (divers pièces alu et carbone anodisé orange, vert, alu, noir)
http://www.teamstrc.com/index.php?route=product/category&path=68
Vanquish
http://www.vanquishproducts.com/axexote.html
support moteur et diff central
Option pour l' exo  Yhst-110
A venir prochainement.....
Tour arrière et avant
Option pour l' exo  8BCE3244-9643-474F-94FD-8402AB283FDC-12181-00000CD72C7028EE
Fusée av
Option pour l' exo  22851DFF-786E-4255-9115-4500EE5DAAD7-20322-000015B48145A07D_zpse7ff2936
RPM
http://www.rpmrcproducts.com/products/Axial/EXOParts.htm#EXOArms
Triangle av/ar
Option pour l' exo  70472
Option pour l' exo  70452
GPM
triangles alu et autre fusée......
Option pour l' exo  EX055ORANGE
Option pour l' exo  EX022SILVER
http://www.thetoyz.com/search2.lasso?keyword=EX0
Biellettes en titane
Option pour l' exo  2910
1 - 3mm x 1 1/2" Punisher Titanium Turnbuckle (Servo)
2 - 4mm x 60mm Titanium Turnbuckles (Steering)
2 - 4mm x 65mm Titanium Turnbuckles (Front Camber)
2 - 4mm x 75mm Titanium Turnbuckles (Rear Camber)
http://www.lunsfordracing.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LUNS&Product_Code=2910&Category_Code=CARS-AXEXO
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeVen 4 Mai 2012 - 20:07
Les options strc arrive cheers
Voir ici http://www.rccaraction.com/blog/2012/05/03/sneak-peek-at-axial-exo-buggy-option-parts-by-st-racing-concepts/
tibure
tibure
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeLun 7 Mai 2012 - 6:59
je vient de voir ces nouvelle option mais pas trouvez d'endroit pour les acheté
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeLun 7 Mai 2012 - 13:00
Normal elles ne sont pas encore dispo mais bientôt. Info sur leurs site
5/3/2012 update: Axial EXO Buggy Aluminum option parts have arrived. More information coming soon.
Soit
03/05/2012 mise à jour: Axial EXO pièces en aluminium Buggy options sont arrivés. Plus d'informations bientôt.
tibure
tibure
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeLun 7 Mai 2012 - 16:14
merci pour l'info
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeJeu 10 Mai 2012 - 17:14
Hello
Option dispo sur le site teamstrc Wink
Y en a ben c' est abusé les prix par rapport au blitz Crying or Very sad
Mais j' ai quand même passé commande clown
tibure
tibure
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeVen 11 Mai 2012 - 6:34
hotracing a egalement sorti d'autre option
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeLun 14 Mai 2012 - 16:09
lien hot racing : http://www.hot-racing.com/index.cgi?c=697 Wink
tibure
tibure
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 15 Mai 2012 - 6:14
de nouvelles option chez STNC
Option pour l' exo  Strc_exo_021
Option pour l' exo  Strc_exo_031
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 15 Mai 2012 - 13:01
Heu rien de nouveau par contre oui je ne l' avais pas dit mais comme d' hab il y a plusieurs couleurs Orange, Vert, Alu, Noir et petite réctif c' est STRC ou teamstrc Wink ICI
Les options Axial des cardans CDV sont aussi dispo un peu partout AV réf AX30415 AR AX30417
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMer 16 Mai 2012 - 20:39
nouveaux options axial ( pas trouvé sur leur site )
http://www.area52.cc/news/2270-axial-exo-terra-buggy-option-parts.html
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMer 16 Mai 2012 - 20:50
Hihihihi tu es rapide petit sacarabé mais j' étais en train de mettre les tof comme il faut Wink
Arbre 3mm
Arbre 5mm
Edit
arff y avais pas tout
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMer 16 Mai 2012 - 20:59
je viens de voir ça, donc ...
ça vaut le coup ?
putain, si je le prends, je vais me ruiner Sad pale
vous faites chier , mais ça me fait envie love
faut que j'en parle a madame ...
j'ai commencé a remonter le wraith cet aprèm
nouvelle carro alu commandé pour me redonner la force, après 6 mois de dodo ...
Option pour l' exo  Imag0102
Option pour l' exo  Imag0103
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMer 16 Mai 2012 - 21:25
Oui moi j' en ai pris pour 100$ chez strc une ruine cette exo mais que fait on pas pour le plaisir des yeux et du reste Very Happy
Sympa la caro alu sur le wraith cheers
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeVen 18 Mai 2012 - 18:20
j'ai juste les cardans avant option qui doivent arriver
mais pour le reste vais voir
couronne acier et cardans arrière pour commencer
le reste en fonction de casse et du compte en banque
au fait quelqu'un aurait une technique pour rattraper une CB ???????? la mienne se sauve dès qu'elle me voie et en plus lle court vite cette saloperie rire
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeDim 19 Aoû 2012 - 10:51
News option Very Happy
Vanquish motor mont.
Option pour l' exo  Vanqui10
http://www.vanquishproducts.com/axexotebumom.html
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 21 Aoû 2012 - 11:49
je l'ai commandé hier, j'ai cassé le mien, alors qu'il a roulé 2mn gatlin2
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 21 Aoû 2012 - 12:45
Arfff j'avais vue que certain avait eu des soucis comme toi Shocked Axial a même fait un exemple pour comment bien le monter Wink pour l' instant le miens tien bon Rolling Eyes
Tu pourrais nous faire une tof pour voir ou il a cassé Question
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 21 Aoû 2012 - 12:54
c'est simple, j'ai trop serré, la vis au dessus, je suis passé au travers ...
maintenant, il y a un trou et je serre contre l'axe rire
tu as mis quoi, le truc en plastic ou en alu ? ( là ou tu fixe le moteur ) j'ai mis l'alu Wink
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 21 Aoû 2012 - 13:09
J' ai mis l' alu avec du frein filet sur les visses Wink puis serrage en douce d' après mes souvenir Laughing
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 21 Aoû 2012 - 13:14
ben, après 2mn d'essaie, le moteur c'est écarté, plus d'entrainement, donc, j'ai serré plus fort ...
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 21 Aoû 2012 - 16:04
c'est drole le mien bouge pas et pourtant il en a pris plein la gueule en 3S et plein gaz en 2S sur un parcours de scale dimanche
par contre je crois bien que ma direction a morfler , y a un arbre qui a traverser juste devant , et puis un summit qui est passé dessus et des racine et des caillasse , sans oublier les pomme de pin retrouver dedans .............. Very Happy
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 21 Aoû 2012 - 17:21
ben, surement un défaut dans l'alu ??
je l'ai essayé samedi sur la place en bas de chez moi, quelques tours de roue et un bruit de crécelle
je suis remonté, et suis partie au boulot
le réglage a été fait sur le terrain dimanche, mais, j'ai serré, mais sans plus, en reposant la voiture, elle faisait un quart de tour de pignon et bloquait
avec mes yeux, j'ai demandé de l'aide, et personne comprenait, après le démontage on a vu le trou ...
et en le tripotant, un bout c'est cassé dans la main, un bout plat avec le logo axial ??!!
je pense plutôt pour de l'alu de merde
je viens de voir ça, trop tard ... lol! > http://www.axialracing.com/blog_posts/9974
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 21 Aoû 2012 - 17:59
Ah tu l' avais pas vue Shocked c' est ce que je te dise ils l' on fait un mois après la sorti de l' exo mis aussitôt en Post-it sur rcshortcourse Wink Idem pour moi pas bougé malgré les sauts et autre rencontre. Enfin moins d' aventure que notre aventureir Corsaire tout ça en une fois fou
Vous avez vue l' exo qui ce prend pour un crawler sur la tube Question
MessageSujet: Re: Option pour l' exo    Option pour l' exo  Icon_minitimeMar 21 Aoû 2012 - 18:19
met nous la vidéo Wink
dimanche, on a fait une sortie à la dune du pilat, je pensais qu'il avait ses chances, mais ...
une a fait la grimpette plusieurs fois un obao
bonne journée, on va remettre ça l'année prochaine si ça te dis ... le plus dur c'est de trouver une date
il y en a qui on fait plus d'une heure et demis de route ...
en haut de la dune, elles ont fait sensation nos voitures ...
Option pour l' exo
» quel option pour le sc 10
» option indispensable pour sc8e
» [NEWS] Pièces option STRC pour vos SC
» pour le fun
