Le Deal du moment : -39%
399 €
 [News] Kit de transformation XXX-T en SC
2 participants
Adam
Adam
[News] Kit de transformation XXX-T en SC Empty
MessageSujet: [News] Kit de transformation XXX-T en SC   [News] Kit de transformation XXX-T en SC Icon_minitimeLun 19 Juil 2010 - 8:25
Team CRC Short Course Conversion Kit for XXX-T based trucks
[News] Kit de transformation XXX-T en SC Bodyon_frt
[News] Kit de transformation XXX-T en SC Bodyon_rear
Move over you other LCG Short Course Trucks, the dominant Losi XXX-T platform has just entered the SC category as well, (with a little help from Team CRC!). What else can we say about this truck that Team Losi hasn't already proven on the race track over the last decade or so. The truck handles extremely well and has excellent durability too. It's light, nimble, and has always been class leading in chassis, suspension, and tuning feature innovation.
Now you can pull those XXX-T's off the shelf that you sidelined when the Short Course craze started, and convert them into the baddest SC Truck on the track. This set converts most all XXX-T truck kits from Team Losi, including the Desert Truck (pictured here) & XXX-T CR utilizing carbon fiber chassis extensions that allow you to use your stock rear bottom plate. Using the stock rear bottom plate makes converting any XXX-T a breeze because there will be no complications with the rear arm mounts, transmissions, etc not matching up. RTR's, MF 1's, MF 2's, Desert Trucks, and the newest XXX-T CR's can all be converted using this setup. (the CR will require you to replace the quick change hubs and axles over to standard type axles).
[News] Kit de transformation XXX-T en SC Frtblk_bdypost
[News] Kit de transformation XXX-T en SC Rear_end
[News] Kit de transformation XXX-T en SC Rear_bottom
The conversion does require you to drill two small 4-40 size holes in the front bulkhead, but this is very easy to do, and a drill bit is even included in the kit so you don't have to track one down. As you can see in the pictures below, the front bulkhead is already pre-marked! All you have to do is drill a hole in the center of each mold mark, and BAM...the front body mount is on.
7700 SC conversion for XXX-T trucks (w/ bumpers) 800734077008
7701 SC conversion for Desert Truck (no bumpers) 800734077015
As you can see in the pic above, you can trim out the plastic backstop in the XXX-T chassis, giving you the most front to back battery adjustment of any SCT. (just don't cut the whole bridge out or you won't have anywhere for your battery strap to attach to).
Meets all ROAR rules for SC truck dimensions. Body and Tires NOT included. Uses SC10 style wheels from any of the popular wheel manufacturers, or you can also add the hex adapters from the Losi Strike and use Strike wheels!
www.teamcrc.com
http://www.t3t4webservice.com/XXXTSC.html
Source:
http://www.petitrc.com/_forumphp/showthread.php?t=51072
MessageSujet: Re: [News] Kit de transformation XXX-T en SC   [News] Kit de transformation XXX-T en SC Icon_minitimeLun 19 Juil 2010 - 8:53
Bonjour
Sympa la transformation avec un peu de carbon top Very Happy
» [NEWS] Losi XXX-SCB
» [News]Associated Pro SC 4x4
» [NEWS] Stamped 4x4
» [NEWS] Summit VXL 1/16 !!!!
» [NEWS] Roues SC par AKA
