-40%
-40% sur le Pack Gaming Mario PDP Manette filaire + Casque filaire ...
29.99 € 49.99 €
 Erik Shauver’s Blitz Tech and Teardown Thread
Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 Empty
MessageSujet: different wiring   Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 Icon_minitimeMer 17 Mar 2010 - 19:12
While I'm at it, I also shortened the wires a bit and am keeping them more centralized.
Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 4348985046_7665bec5a8_o
note: this is still a preproduction ESE, so a few of the bits are missing...
MessageSujet: Re: Erik Shauver’s Blitz Tech and Teardown Thread   Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 Icon_minitimeJeu 25 Mar 2010 - 18:50
une partie interessente qui n'est pas référencé
http://www.rcshortcourse.com/forum/showpost.php?p=24390&postcount=55
One step even further with the steering rack would be to flip it over. Hole 2 is standard. Hole 1 picks up more steering, entry to mid corner. I'm going to try hole "3" as soon as I can get out to race. It should take things another step further.
Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 4100695707_9834ee9327_o
Note you'll need to dremel or otherwise cut at roughly the dotted line.
Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 4101451180_b844ef4c54_o
Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 4101451222_64e93fc5f4_o
This is to provide clearance here.
Note: I haven't tried this yet, so it may be "out of range" so to speak, but since most of you seem to be handy with a dremel :thumb:
Reset your EPA once modified.
le-fou-du-SCORR !!!
le-fou-du-SCORR !!!
MessageSujet: Re: Erik Shauver’s Blitz Tech and Teardown Thread   Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 Icon_minitimeVen 4 Juin 2010 - 22:16
Gilou a écrit:
Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 4091263148_f9dd416a3f_o
7. rough setting for max steering while retaining some protection... too tight like gluing and locking down the saver (YES we tried it) will make the front end unpredictable on 1 wheel landings.
Salut, je ne comprends pas cette modif', quelqu'un pour m'aider !? confused study scratch
MessageSujet: Re: Erik Shauver’s Blitz Tech and Teardown Thread   Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 Icon_minitimeMar 29 Juin 2010 - 12:08
Ce n'est pas une modif ; c'est le réglage du sauve servo.
Pour un bon réglage, il te conseil de mettre la partie supérieur de l'écrou à 1,51mm du haut du filetage.
el_chemist
el_chemist
MessageSujet: Re: Erik Shauver’s Blitz Tech and Teardown Thread   Erik Shauver’s Blitz Tech and Teardown Thread - Page 2 Icon_minitimeMar 20 Mar 2012 - 11:20
je déterre car j'ai tenté ce réglage il y a quelques jours...catastrophe !
L'écrou n'a pas voulu bouger, en revanche, c'est toute la pièce métallique qui à commencé à tourner dans le plastique. Du coup j'ai tourné dans l'autre sens pour la remettre en place, mais j'ai une légère déformation du plastique quand je regarde par dessous.
L'écrou doit être bloqué au frein filé.
A quoi sert exactement ce réglage ? à assouplir la direction ?
J'espère ne pas avoir créé une faiblesse ou un jeu.
» blitz en 3s
» Les BLITZ du SUD!!!
» Le Blitz ESE de Fox'
» MON BLITZ !!!
