LEGO Icons 10331 – Le martin-pêcheur
35 €
anipassion.com
 Class 9 ..
Class 9 .. Empty
MessageSujet: Class 9 ..   Class 9 .. Icon_minitimeMar 12 Jan 2010 - 17:13
Class 9 .. DSCN2795
Class 9
Aka: Challenger
Horsepower: 72-76 (dual port)
Wheel Travel: 5.5 Front, 9.5 Rear
Weight: 1450-1600 Pounds
Top Speed: 80+mph, 130+ km/h
Cost New: $8,000-15,000
Cost Per Prep: $1,000-2,500
Basic Rules:
Engine and Drivetrain:
- Nearly stock type 1
1600cc engine is required. Case is open. Camshaft is open. Compression
is limited to 7.5 to 1. Dual port heads are allowed.
- Transmission is limited to swing-axle. Stock 1st and 2nd gears must
be retained. 3rd and 4th are open. R&P must be 4.12 or 4.37. Case
is open.
Suspension:
- Stock type 1 suspension components must be used throughout. No
modifications are allowed to stock parts except for the spindles. The
may be reinforced and the speedometer hole filled. Must run ball-joint
front end. Strengthening of beam is allowed by way of one tube attached
at each shock tower. Must use stock front shock mounts.
- Rear shock mounts are open. Spring plates are open. Torsion adjusters are allowed.
- Maximum shock size is 2.5 inches. No external bypass allowed. No hydaulic bump stops allowed.
Other:
- Brakes must remain stock VW but type 3 and thing drums are allowed. Drilling is allowed. May use 4 or 5 lug.
- No aluminum wheels are allowed.
- No power steering allowed. Tie rods and tie rod ends/heim joints are open.
Class 9 ..
» Class 1 ...
» Class 10 ...
» Class 8 ...
» Class 5 ...
» Class 7 ...
Forum BITD, SCORR, SC :: Les chassis officiels 1/1 :: Présentation des classes courue-
