Here comes the Latest Eurgle 3 Channel Radio Gear. Pre-installed Fail Safe Function, make a Safer Ride and better protection to your Car & Boat! Upgraded Larger Monitor with Ultra-Bright Background Light, placed on top makes sure you can read clearly!
2.4Ghz provides the most stable and least interference communication. Less crystal minimized your cost for and broden the limit. You can use upto 8 models for this Radio Gear.
Fail Safe Function gives you the best protection to your RC Model. Simply Few-Steps set-up before you run, everthing is under control!
Free Simulator Software compatible, low-cost like spending on FM/AM Radio Gear, why don't have a try?
Features: Fully digital signal, no interference at all.
Less devices - No Module required.
Comaptible with VRC Simulator
ABS System
9 Model Memory
Specification:Transmitter / Receiver : 2.4GHz
Compatibility : Eurgle 2.4Ghz 3 Channel Receiver (3rd Generation)
Power : 8 x AA Battery / 3 Cell Low Current Lipo Battery(Not Included)
Mode Type : Car / Boat
Code Type : Digital
DSC Port : Yes (3.5mm)
Radio Weight : 399g
Receiver Weight : 9g
Cross Weight : 705g
Items included: Eurgle 2.4Ghz 3 Channel 2.4Ghz Transmitter
Eurgle 2.4Ghz 3 Channel 2.4Ghz Receiver
USB Interface
Price: US$42.73
EUR€30.61
http://www.r2hobbies.com/eng/proddetail.php?prod=rcps2805004
