Le Deal du moment : -21%
TOSHIBA 50UA3A63DG TV 4K UHD – 50″ (126 ...
332.62 €
 Copie du 4*4 de chez FG a prix imbattable !!!
gof
gof
Copie du 4*4 de chez FG a prix imbattable !!! Empty
MessageSujet: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeJeu 28 Juil 2011 - 11:31
Ils sont fort ces chinois, ça va faire très mal sur le marché mondial du tt 1/5, car ils viennent de sortir une copie parfaire du monster 4*4 de chez FG, à 410€, alors que pour le modèle de la marque d'origine il faut compter 900€ environ...
ça ce passe de commentaires !!!
Lien !
Crush the competition with the HobbyKing Big Monster! anyone that tells you bigger is not always better has never driven this 1/5th scale Gas burning beast! With 200mm off road tires, big bore aluminum shocks and a tuned pipe as standard this 26cc 4WD mammoth will clear anything in its path.
The Big Monster also includes twin High Torque steering servos, rear disc brake and a massive 530ml fuel tank. All that is needed to complete this truck is your own transmitter and receiver, paint to customize the body shell and a tank of 2-Stroke Gas!
Specs.
Engine: 26cc Petrol (2 Stroke)
Compression ratio: 6.8:1
Transmission system: Synchronous Belt Drive (4WD)
Brake system: Rear Disc
Size: 760mm x 500mm x 360mm (L*W*H)
Wheelbase: 500mm
Ground Clearance: 70mm
Tire size (front/rear): 200mm x 120mm
Fuel tank volume: 530ml
Steering: 2 x High Torque Servos (Included)
Throttle/Brake: 1 x Standard Servo (Included)
Included:
Receiver battery and charger
2 x High Torque steering Servos
1 x Standard throttle/brake servo
Tool Set
Fuel Mixer bottle
Air filter
Spare Parts
Required:
Your own TX/RX
Paint for Body Shell
Note: Full range of spare parts will be available soon!
MessageSujet: Re: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeJeu 28 Juil 2011 - 14:35
l'inconvénient de ce genre de trucs chinois, c'est que pour arriver à la fiabilité d'un FG, il faut ajouter environ le prix d'un FG en options What a Face
gof
gof
MessageSujet: Re: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeJeu 28 Juil 2011 - 15:07
je te rassure pour avoir possédé 2 châssis Fg, pour qu'il soit fiable il te faut aussi pas mal l’optionner donc si déja tu commence avec un châssis la moité moin chère c'est toujours ça de gagné !
Baptiste
Membre Pelo Team
Membre Pelo Team
Baptiste
MessageSujet: Re: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeJeu 28 Juil 2011 - 19:18
Je confirme, un pote a eu un FG et il avait pas mal de couilles avec (du style platine radio qui se plie sous la force du servo donc impossible d'avoir du frein, etc.
Copie du 4*4 de chez FG a prix imbattable !!! 00c925c41e5f3a42...3d6f02e-338aba3
MessageSujet: Re: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeJeu 28 Juil 2011 - 21:33
Le seul intérêt, c'est qu'il a un moteur 4 temps !
MessageSujet: Re: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeVen 29 Juil 2011 - 8:29
gné ? drunken
qué moteur 4 temps ? Ca n'existe pas dans les voitures RC à moins de 10000 Euro... What a Face
Baptiste
Membre Pelo Team
Membre Pelo Team
Baptiste
MessageSujet: Re: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeVen 29 Juil 2011 - 8:47
Je sais pas ce que ça doit donner un 30cc 4tps...
MessageSujet: Re: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeVen 29 Juil 2011 - 9:02
"2 stroke" c'est pas "2 soupapes" ?
MessageSujet: Re: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeVen 29 Juil 2011 - 11:20
2 stroke c’est 2 temps .... ishhh
pis voila les fdp et la douane quand la bette arrive !!!!
Projet 2010/2011/2012
MessageSujet: Re: Copie du 4*4 de chez FG a prix imbattable !!!   Copie du 4*4 de chez FG a prix imbattable !!! Icon_minitimeVen 29 Juil 2011 - 11:25
ha ba là t'as carrément le droit à la camionnette Bleue et 2 douaniers qui viennent te livrer l'engin et encaisser la taxe lol
» cout d'une location de près?
» clermont
» operation/arthroscopie
» Mini Caméra MD80
» Devis et test pour achat 3 roues
