Partagez
 [NEW] enfin !! pièces RPM pour SC8
[NEW] enfin !! pièces RPM pour SC8 Empty
MessageSujet: [NEW] enfin !! pièces RPM pour SC8   [NEW] enfin !! pièces RPM pour SC8 Icon_minitimeMer 23 Mar 2011 - 14:35
RPM pense a nous, possesseur de SC8, c'est pas trop tôt ...
mais, rien de cassé encore, mais ...
Rear A-arms for the SC8 & RC8
[NEW] enfin !! pièces RPM pour SC8 73922
Whether you’re out having fun bashing or in the middle of the A-main at a national event, nothing is more frustrating than breaking an A-arm. That’s where RPM steps in. RPM A-arms for the Associated SC8 & RC8B are designed to prevent that from ever happening again. These A-arms are tough as nails and designed to take some serious punishment! Every aspect of the design on these arms is there to either improve strength or durability. Additionally, we’ve cleared the A-arms in areas known to rub on the stock A-arms, allowing extra droop for more suspension travel over rough terrain or big jumps.
Exclusive features of RPM A-arms include: Molded-in shock mounts which means no more lost screws or extra weight from those screws on the arms (each RPM Rear A-arm is actually 3 grams lighter than stock, saving 6 grams of unsprung weight!). Elimination of the stock lower shock mount pin in favor of a new 5-40 screw, which eliminates .004” of slop in the pivot and improves suspension accuracy. Leading and trailing 30-degree edges help the vehicle to more easily transition up and over objects too tall for the suspension to clear and improve suspension aerodynamics.
RPM A-arms are molded in our trademark blend of bulletproof nylons and are factory-backed by our industry-leading breakage warranty. Molded in black and sold in pairs with one left and one right A-arm in each package.
73972 Rear A-arms for the SC8 & RC8
Available 04.12.11
Suggested Retail
$15.95 / pair
Front A-arms for the SC8 & RC8
[NEW] enfin !! pièces RPM pour SC8 73972
RPM front A-arms for the SC8 & RC8B are built with the same principles and design characteristics built into all RPM A-arms. Some of those design considerations include cleared areas known to rub on the stock A-arms. We also molded in the shock mounts, which means no more lost screws or extra weight from those screws on the arms (RPM Front Lower A-arms are slightly lighter than stock!). To help reduce slop in the suspension, we discarded the stock shock mount pin and setscrew in favor of a new 5-40 screw, which eliminates .004” of slop in the pivot and improves suspension accuracy. Leading and trailing 30-degree edges on the a-arms help the vehicle transition up and over objects too tall for the suspension to clear and, as a side benefit, those angles improve suspension aerodynamics. All this comes at a weight identical to the stock arms!
RPM A-arms are molded in our trademark blend of bulletproof nylons and are factory-backed by our industry-leading breakage warranty. Molded in black and sold in sets, including one lower left A-arm, one lower right A-arm, two upper A-arms and all necessary hardware in each package.
73972 Front A-arms for the SC8 & RC8
Available 04.12.11
Suggested Retail
$17.95 / set
Wink
MessageSujet: Re: [NEW] enfin !! pièces RPM pour SC8   [NEW] enfin !! pièces RPM pour SC8 Icon_minitimeMer 23 Mar 2011 - 18:36
Enfin, nos petits SC8 vont avoir des pièces rien que pour eux chez les optionneurs cheers
Mais les pièces d'origines sont si solides que je me demandes si cela vaut le coup scratch
Quoique avec ces pièces, mon SC8 va pouvoir gagner 6 grammes rire
MessageSujet: Re: [NEW] enfin !! pièces RPM pour SC8   [NEW] enfin !! pièces RPM pour SC8 Icon_minitimeMer 23 Mar 2011 - 18:48
RPM font des pièces pour les 1/8, c'est inquiétant rire
MessageSujet: Re: [NEW] enfin !! pièces RPM pour SC8   [NEW] enfin !! pièces RPM pour SC8 Icon_minitimeMer 23 Mar 2011 - 19:43
ils en feront surement pour losi rire
MessageSujet: Re: [NEW] enfin !! pièces RPM pour SC8   [NEW] enfin !! pièces RPM pour SC8 Icon_minitimeMer 23 Mar 2011 - 20:34
M'en fou, le mien c'est un 1/10 study
» Où trouvez vous des pièces alu pour faire un cadre carbone ?
» gros soucis pour trouver des pièces neuves pour moteur de mon 404
» enfin une bombe pour les tout petit !! photo de lola avec!
» Enfin un stade pour le LOSC
» Pièces utiles pour les trikes home made
Ne ratez plus aucun deal !
IgnorerAutoriser
