Le Deal du moment : -78%
Batterie externe 26800 mAh à charge rapide
23.95 €
 [NEW] for slash 2WD Performance Steering Kit
[NEW] for slash 2WD Performance Steering Kit Empty
MessageSujet: [NEW] for slash 2WD Performance Steering Kit   [NEW] for slash 2WD Performance Steering Kit Icon_minitimeMer 16 Fév 2011 - 23:01
[NEW] for slash 2WD Performance Steering Kit 6067-00
[NEW] for slash 2WD Performance Steering Kit 6067-00-1
[NEW] for slash 2WD Performance Steering Kit 6067-00-2
Description
Slash®, Rustler® are registered trademarks of Traxxas® L.P
This is Pro-Line’s Performance Steering Kit for 2WD Slash® and Electric Rustler®. Do you want to take your Slash® to the next performance level? Whether you are racing or bashing, the increased steering response and precision provided by Pro-Line’s Performance Steering Kit will lead to faster lap times and more fun! The kit includes ball bearings for silky smooth steering action and an adjustable servo-saver that allows you to control the desired amount of steering response, while still protecting your servo. As an added bonus, Pro-Line’s development team eliminated possibility of the steering popping out by bolting the steering column through the chassis. Pro-Line’s steering kit is a must for every 2WD Slash® and Electric Rustler®!
The stock servo-saver is not ideal for racing or bashing conditions because it allows the front wheels to drift from side-to-side too much and you lose precise control. Pro-Line’s steering kit gives control back to you because you can adjust the exact amount of tension on the servo-saver. The steering kit also eliminates the stock white plastic steering assembly and replaces it with durable black nylon for that race look that you desire. Ball bearings are also a requirement when you desire smooth and precise steering response and these are included with the Pro-Line Performance Steering Kit. After buying and installing this steering kit you will never have to worry about the steering kit popping out ever again. The kit includes the necessary hardware to bolt the steering and skid plate to the chassis, which makes the front end stiffer and stronger!
Don’t forget to check out Pro-Line’s other great accessories for the Slash® 2WD, like the ProTrac Suspension Kit and the PowerStroke Shocks!
instruction de montage
lien >> http://prolineracing.com/performance-parts/performance-steering-kit/
MessageSujet: Re: [NEW] for slash 2WD Performance Steering Kit   [NEW] for slash 2WD Performance Steering Kit Icon_minitimeJeu 17 Fév 2011 - 8:39
Pareil que sur l'autre site:
30$ pour du plastique.... donc à voir scratch
» [New ]slash 4x4 brushless
» Slash 2wd Parts
» Entretient Slash VXL.
» power steering sur apex 2011
