Funko POP! Jumbo One Piece Kaido Dragon Form : ...
 Class 11 ...
Class 11 ... Empty
MessageSujet: Class 11 ...   Class 11 ... Icon_minitimeMar 12 Jan 2010 - 17:15
Class 11 ... DSCN2750
Class 11:
Stock production VW bug with roll cage and upgraded
shocks and tires.
Horsepower: 72-76
Wheel Travel: 5.5 Front, 5 Rear
Weight: 1950-2100 Pounds
Top Speed: 90 mph, 145 km/h
Cost New: Vehicle + $3,000-5,000
Cost Per Prep: $500-2,500
Basic Rules:
Suspension:
- Front axle tubes may be cut, rotated, re-welded to increase ground clearance or front torsion adjusters may be installed.
- Shock tower may be gusseted and supported but gussets may not extended more than 2'' above the torsion tube.
- Stock front spindles and trailing arms must be retained.
- Any rear suspension torsion bars, spring plates, and torsion bar adjusters may be used and installed.
- Rear torsion tube may be supported, only by that tube meeting a part o the roll-cage.
- Lower shock mounts on 1969 and older models may be shortened by no more than 1.5''.
- Only one shock absorber per wheel is allowed. Cooling fins and resevoirs are allowed.
Engine and Drivetrain:
- Must be of VW Type 1, 1600cc components and dimensions.
- Cylinder heads must be single port.
- Stock carburetor must be used, with maximum venturi size of 24.10 mm.
- Must use stock fan shroud.
- Air cleaner may be of any manufacturer and any size; location is open.
- Transmission must be a stock Type 1, 4-speed bug.
Class 11 ...
» Class 1 ...
» Class 10 ...
» Class 8 ...
» Class 5 ...
» Class 7 ...
Forum BITD, SCORR, SC :: Les chassis officiels 1/1 :: Présentation des classes courue-
