Manga Chainsaw Man : où acheter le Tome 17 ...
19.99 €
 1/2-1600..
1/2-1600.. Empty
MessageSujet: 1/2-1600..   1/2-1600.. Icon_minitimeMar 12 Jan 2010 - 17:08
1/2-1600.. Laughlin04_race_240
1/2-1600:
Single or two-seat buggies limited to 1600cc
Type 1 engine and Type 1 suspension components.
Aka: 2000 (BITD)
Horsepower: 77-82 Single seat (dual port), 82-87 Two-seat (dual port)
Wheel Travel: 9-10 Front, 16-21 Rear
Weight: 1550-1600
Top Speed: 75-85 mph, 120- 135 km/h
Cost New: $30,000-60,000
Cost Per Prep: $2,500-6,000
Basic Rules:
Suspension Components:
Front:
- Suspension is based on VW Type 1 ball join or link pin style
- Any manufacturer's beam of 2 steel torsion tubes may be used but must retain stock VW width.
- Front trailing arms may be reinforced or replaced but must retain stock length and width.
- Track width will be measured from wheel mounting serface to the opposite; maximum is 55 1/2".
Rear:
- Suspension is based on VW Type 1 (IRS) or swing axle
- Trailing arms may be replaced or reinforced as long as length is retained at +/- 1".
- Torsion tube may be replaced or reinforced and torsion adjusters may be installed; any manufacturer may be used.
- Trackwidth may not exceed 58 1/4'' and is measured wheel mounting face to the opposite site.
- Entire outer cv must remain inside of the trailing arm inner bearing; no midboard or out-board hubs allowed.
» 5-1600 ...
Forum BITD, SCORR, SC :: Les chassis officiels 1/1 :: Présentation des classes courue-
